selecting points in an array
HI
I generate a series of sine waves and store the values as an array, next i need to select only those points in the array that correspond to the amplitude of the sine wave i specify. Could anybody suggest how i go about it?
(3,602 Views)
Can you please post what you did so far? Post a sample so that it will be easy for us to help you and also you can learn fast.
Mathan
(3,600 Views)
Hi Mathan
The while loop generates the  amplitude values and i need to select the coresponding points from the array generated in the for loop.
(3,595 Views)
Hi cquark,
as you can't compare floats for equality you should use the InRange? function...
Change the epsilon to your needs (by replacing with a constant)!
Message Edited by GerdW on 11-17-2009 03:13 PM
(3,590 Views)
Since it's a sine wave can't you just use the Min/Max function to get the amplitude.  If you need all instances of the Max you could use Search 1D array.  Or if you know the frequency you should be able to get it just by adding that much to the index of the first max
Message Edited by elset191 on 11-17-2009 08:26 AM
Tim Elsey
Certified LabVIEW Architect
(3,579 Views)
Thank you for the replies. In the vi you modified GerdW i have now included an array(array 3 in vi) such that i can obtain all the points at which the amplitudes were at any specified value, i.e at the max/min i should have 6 points and at any other amplitude i should have 12 points that have the same amplitude. For the abritrary values i have set,  the InRange function seems to be coercing all the points(1000 in this case) to one amplitude, as seen in array3.
I am sorry i have not mentioned why i intend on doing this. I generate a 3D spiral that i need to overlay on a stack of 2D images of fixed z increments, so for every image i will have one or 2 points where the trajectory intersects each image, i need to determine the corresponding (x,y) for each of the points such that i can overlay them on the image.
(3,558 Views)
