self Calibration
Dear all,
We have used the NI PCI 6024E DAQ to test our product under LV6.1  run time  engineer for quite few years,but this afternoon,please refer to the attached pdf file,every time when we start to run test program,self calibration will fail,we checked each wire and connectior,no any problems,so I wondered if the 6024E DAQ card(hardware) failed?any one can help me?
Thanks in advance..
Simon
(3,410 Views)
You can check the card out by using the Measurement & Automation (MAX). Select the device in the Devices and Interfaces tab.
Regards
Ray Farmer
Regards
Ray Farmer
(3,379 Views)
Hi
It is difficult to post the question in Discussion forum.please send the direct link using which i can post the question.Sometimes it becomes very frustrusting.Thats why i am not able to post a new question.So i am doing it by sending the reply of a question.
please help
(3,371 Views)
You just have to follow the instructions at http://forums.ni.com/ni/search?board.id=170&searchbeforepost=true.
Since so many questions get asked over and over again, it's a very good thing that the forum forces you to do a search first instead of just doing a post. You've started many threads before, what exactly is the problem you are having now?
Message Edited by Dennis Knutson on 07-09-2006 01:59 PM
(3,359 Views)
