send a mail when there is an error in program running
I drive some instruments with Labview and I would know, if I am not at work, receive a mail by my program if there is a problem or an error in the program running.
(2,626 Views)
In LabVIEW 7.0 FDS or better you have SMTP VIs in the Communication
function palette. For LabVIEW versions before 7.0 you could use the
Internet Toolkit or try and get SMTP VIs from www.OpenG.org.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
(2,626 Views)
I just would like to send you an example that uses SMTP VIs of LV 7.
(2,626 Views)
