send a signal from lab view to a comm port
Hi, i have this vi and i need to send a signal each time i get an output from an indicator. For example, if the cluster indicator shows "c" then a signal is sent to a port, if it shows "b" another signal is sent to a different port. I need to control relays with each signal and i have a total of 3 signals that need to be sent depending on the output a b and c. can someone help me with this
Message 1 of 10
(3,372 Views)
by the way i am new to labview and here is the vi
Message 2 of 10
(3,369 Views)
Accepted by topic author hawkeye182
Message 3 of 10
(3,350 Views)
thank you so much, i'll give it a try and let you know
Message 4 of 10
(3,317 Views)
Do you really want the com port or the parallel (printer) port?
p.s. The VI you attached will not open.
Message 5 of 10
(3,311 Views)
so sorry, this is the vi
Message 6 of 10
(3,284 Views)
what is the difference between those two? i only need a way to send a signal depending on the result of the search function in my VI.
Message 7 of 10
(3,283 Views)
and btw i am using a macbook with only 2 usb port, if it helps
Message 8 of 10
(3,282 Views)
hi can anyone convert the vi parallel Exp to version 11.0 please
Message 9 of 10
(3,281 Views)
You can always post the vi to our Version Conversion forum to see if someone can convert it for you there.
http://forums.ni.com/t5/Version-Conversion/bd-p/VersionConversion
Carl W.
Applications Engineering
Message 10 of 10
(3,242 Views)
