Hello LV community,
I am sending bits to my parallel port to communicate with my ASIC but I have an issue to enter some test modes which require to send simultanously for example 3 bits at the same time into 3 pins to the port, I can seen from the scope that there are some delays between them (aprox.20 us).
My question is, this delays is it due to the PC performance or the way to send them? I am using the Out Port8.via for thi purpose. Is there any solution for this issue?
Thx
