send email with attachment from windows
    Hi there,
I need to send an email with programatically generated content from a LV application.
I have tried use ActiveX automation but can't seem to even open the  Outlook._Application object!
So instead I am trying to use the command line by invoking url.dll
(so this is not strictly a LV related question, just though someone may know the answer)
To create a new email, the following command works fine:
rundll32.exe url.dll,FileProtocolHandler mailto:%s  &Subject=%s &body=%s
where the %s are replaced with something sensible at runtime. This seems to work fine.
To add an attachment, either &attach or &attachment are used, however I cannot get either of these to work properly
rundll32.exe url.dll,FileProtocolHandler mailto:%s  &Subject=%s &body=%s &attachment="c:\\test.zip"   gives no joy Smiley Sad
I have tried messing around with all sorts of combinations of escape characters for the "\"s and " " "s howevero with no luck. Best case scenario is the email is generated with no attachement, worst case is Outlook (2002 SP-2) complains the command line argument is not valid and the switch is incorrect.
Any advice???
Message 1 of 8
(5,904 Views)
Yes. Don't try to use Outlook via ActiveX. Smiley Wink
Seriously, there are easier ways:
  • Does your email server require authentication? If not, you can use the built-in LabVIEW functions in the SMTP palette.
  • Use the Internet Toolkit (though you need to buy this).
  • You can use the .NET libraries.
  • You can use the OpenG SMTP libraries. You can get a modified version that meets the no-linefeed-only-lines rule from this thread.
Message 2 of 8
(5,893 Views)
I am quite sure the email server does require authentication, but anyway I only have the base edition of 7.1 which excludes the SMTP functions.
Don't really want to buy anything, this little project is just a way of saving me time (in the long run), but probably doesn't justify any expenditure.
.Net I have not tried, I will give it a whirl
OpenG is also a no-goer as I cannot install any packages using their internal downloader as the firewall/proxy settings dont seem to work properly... I have not tried this in a few months though so maybe its been fixed?
Message 3 of 8
(5,889 Views)
I had to do something similar and ended up using an auto-hotkey script to actually control outlook itself, because my boss REALLY wanted the stuff in his mailbox.  This was a horrible way to do it.
I was quite happy with my previous solution, which involved putting the files themselves on an ftp server, and sending emails with links to the files via the command line.
Message 4 of 8
(5,878 Views)
I'm not sure what you mean when you say you can't install using their internal downloader. Whose internal downloader? The OpenG library is a pretty easy solution. The link I gave earlier is incorrect. The correct thread is http://forums.ni.com/ni/board/message?board.id=170&message.id=220354. I had posted a 7.1 version of the library in that thread.
Do you want me to just email you the library? It's about 200K.
Message 5 of 8
(5,871 Views)
I meant using the openG commander to install the packages...
Thanks for the link, I have downloaded the library. Now I just have to figure out if I can use it with our internal MS Exchange server?
cheers!
Message 6 of 8
(5,866 Views)
Ah, should have mentioned you were tyring to do it with Exchange. In that case, I retract my original statement and suggest that you look at the VI posted in this thread:
http://forums.ni.com/ni/board/message?board.id=170&message.id=92583&requireLogin=False
It should get you started. You can add attachments by writing to the "Attachments" property of the "MailItem" object.
Message 7 of 8
(5,858 Views)
thanks for the link, but that VI is basically the same as the one I initially tried, however I get error message:
Error -2147312566 occurred at Error loading type library/DLL.
 in Send_Outlook_Mail.vi
immediately after the Automation Open function.
I have used this automation open sucessfully with an Excel object, however no such luck with using an Outlook object. I suspect it may be an incorrectly configured/registered installation of Outlook on my PC.
Message 8 of 8
(5,816 Views)
