send mail from real time
can i send email from real time (vxworks) cRIO. using smtp vi's.
Message 1 of 10
(3,764 Views)
Hi mazhar.ali,
afaik you can send normal tcp messages over LAN so it should also be possible to send emails.
Mike
Message 2 of 10
(3,747 Views)
thanx
i hav to only use cRIO
Message 3 of 10
(3,744 Views)
Hi mazhar.ali,
what do you mean? Is your cRIO connected to the LAN? There are some third party modules for gsm.
Mike
Message 4 of 10
(3,730 Views)
yes my cRIO is on LAN
Message 5 of 10
(3,727 Views)
Hi mazhar.ali,
ok, then i see no problem in sending emails with it.
Mike
Message 6 of 10
(3,724 Views)
sorry first my cRIO is connected via cross cable to my system
now i hav connctd to router via straight cable now i am not accessing my cRIO is there any settings to be changed
Message 7 of 10
(3,722 Views)
Hi mazhar.ali,
did you change the ip adress of the cRIO? It shoult be something like yours. I think the default adress is 0.0.0.0 and this could be a problem for your router.
Mike
Message 8 of 10
(3,716 Views)
no i hvnt change ip
Message 9 of 10
(3,707 Views)
Hi Mazhar,
Please look at this discussion forum for more information on using smtp with your cRIO. At this point, as I understand, you are connected using a router on the same subnet. As mikes81 has pointed out you do have to configure the IP settings accordingly.If you set MAX to obtain IP settiings automatically it should populate all the fields by itself. Hope this helps!
Ipshita C.
Message 10 of 10
(3,664 Views)
