sending ascii and hex data using visa serial port
Hi All,
I am a noob to the whole labview development enviroment and have searched all over the forum to try and find some answer but have had no luck so far.
Currently I am trying to implement serial communications using the serial port library vi (used in the basic serial read and write example) with a board that requires both ascii and binary data to be sent to it.
For example  this is how it is sent out in Visual Basic
MSComm1.Output = "!B" + Chr$(IOVal)
where Chr$(IOVal) is equivalent to $00 to $FF
I have looked and started modifying the Basic Serial read and Write vi and am not having much luck as I believe the Serial VISA only sends out ASCII values.
I can send out the ASCII to the serial port quite easily but I am having difficulties sending the binary data.
Is there any solutions where you can send both ASCII and binary data in a single string?
Thanks for your answers
Stolzie
(6,368 Views)
Check out this link from an earlier thread.
P.M.
Putnam
Certified LabVIEW Developer
Senior Test Engineer North Shore Technology, Inc.
Currently using LV 2012-LabVIEW 2018, RT8.5
LabVIEW Champion
(6,363 Views)
LV Pro
Which link ? Instead of criticizing other's posts ;), you should take care of yours ! :D:D:D
Chilly Charly    (aka CC)
(6,360 Views)
Oops, got me CC! I am tired, up too early, up too late.
http://forums.ni.com/ni/board/message?board.id=170&message.id=41213&requireLogin=False
P.M.
Putnam
LabVIEW Champion
(6,353 Views)
Thanks LV_Pro this is exactly what I am after
(6,348 Views)
