sending binary file via RS232 connection
I want to send a binary file via RS232 connection but I have troubles reading the .bin file and then converting the data to string in order to send it via RS232. Any ideas how i can deal with this?
Thanks in advance,
IG.
(3,833 Views)
It is hard to help then you do not post any code. I suggest you go to the toolbar then help. Then you select Find Examples. Search for files. Also since you are new to Labview always have context help enabled. Both tools are important if you want to learn Labview. Feel free to post again if you are stuck.
Besides which, my opinion is that Express VIs Carthage must be destroyed deleted
(Sorry no Labview "brag list" so far)
(3,829 Views)
Hi igurov,
you can use the "Read From Binary File" function. You'll get your data directly as string.
Mike
(3,828 Views)
