sending cntl-D as a string
How can I send a CNTL-D via a string control to the serial write.vi? No matter what I do I can't seem to send this as correctly and I need to be able to use this to stop a serial device from sending data. Any good ideas out there?
(3,270 Views)
Ctrl-D in the ASCII set is actually a hex 03... just cast the U8 hex value
03 to a string ( cast is located in the Advanced-Data Manipulation palette)
Good luck,
Bill
drval wrote in message
news:506500000008000000634E0000-1023576873000@exchange.ni.com...
(3,270 Views)
Thanks for the input but I guess I'm just too long away from "working in the trenches" at the low levels of serial interface. I understand what you've posted but can't seem to get it to work correctly. Can you post me an example of the U8 hex of 03 being cast to a string?
(3,270 Views)
drval,
Place a new string control on a front panel. Right-click on it and select Hex Display. Type '03' into the string control. You now have a Ctrl-D.
Randy Hoskin
http://www.ni.com/ask
(3,270 Views)
Actually this is what I did so here's the problem. This doesn't work to stop the device from transmitting data. When I'm using Hyperterm and I hit CNTL-D, the device stops sending data. I thought I was entering the code incorrectly but I see now that I was, apparently, entering it correctly but it was not having the correct effect.
Any other ideas about this?
(3,270 Views)
Ctrl-D is the ASCII "End Transmission" character and is 04hex, not 03hex.
LabVIEW, C'est LabVIEW
(3,270 Views)
