sensor filtering
I am using Interface force sensor (load cell), Labview 8, and E6062 DAQ card. The data from the sensor is noisy and I need to filter it. The bandwidth of my signal conditioner is 60Hz, and when I send my data in the labview from the DAQ assist to Filter (low pass filter, with butterworth topolgy) I get an error, althought I assign the cutoff frequency 0.5 sample frequency. Any suggestion?
Thanks, Azadeh
(2,863 Views)
I won't be able to run your code immediately because you use the DAQ assistant which makes it hardware dependent - however if you can post the error message I will try to help you further.  Also, you should definitely check out the shipping examples in the example finder, as you'll find filtering examples there to serve as an example for you!
Best Regards,
JLS
Best,
JLS
Sixclear
(2,846 Views)
