sensors
How do I convert a voltage reading to a pressure reading? Sensor number is: MPX5050GP
(3,756 Views)
What DAQ device are you using to measure the voltage?  It can be as simple as applying the appropriate scale either in MAX or in the setup of the channel in LabVIEW.
(3,746 Views)
The DAQ device is a NI USB-6212 , 16 inputs, 16-bit, 400 kS/s, Multifunction I/O.
(3,741 Views)
The datasheet for that sensor shows a very linear curve for that sensor. You should easily be able to create a scale in MAX or the setup of the channel in LabVIEW as Ravens Fan indicated. Please consult the documentation on MAX and DAQmx on how to create scales.
(3,732 Views)
Here's a good article on custom scaling in MAX, and this one shows how to use this in LabVIEW once creating a custom scale in MAX.
Tejinder Gill
Visit ni.com/gettingstarted for step-by-step help in setting up your system.
(3,684 Views)
(3,676 Views)
