separate integer digits to array
Greetings all
Can someone tell me how do i separate integer in to separate digits in an array.
Eg: 4409
array elements: 44
                            9
Thanks and Regards
Baig
Message 1 of 9
(5,707 Views)
Aren't these four digits: 4 4 0 9 ?
Message 2 of 9
(5,675 Views)
Hi
it is but since those are integers 09 will be 9
Thanks and regards
Baig
Message 3 of 9
(5,664 Views)
So you don't' want to separate digits.  You want to separate PAIRS of digits?
Message 4 of 9
(5,633 Views)
This is how I would do it. If you change the 2 to a different number it would give how ever many digits.
Tim
GHSP
Message 5 of 9
(5,627 Views)
I would use Quotient and Remainder and divide by 100.
Message 6 of 9
(5,608 Views)
You are still not giving us sufficient information.
  • Is the input a string with four character or a numeric?
  • If it is a numeric, what is the datatype?
  • Are negative inputs allowed, and if so, how should they be handled?
  • Is it always four digits or can it be variable length?
  • What should be the output datatype?
Typically it is much easier to solve a problem if you would attach a very simple VI that contains the actual data and desired output.
Here's a slightly more scalable version of the above that can deal with any number of digits supported and will output all decimal digit pairs of the positive input integer.
Message 7 of 9
(5,590 Views)
All of the previous methods have been a simple way to accomplish this problem, so I decided to make a hard way to accomplish this problem. I also assumed that the task is to get each single digit, not pairs of digits; if you want pairs of digits, that is left as an exercise to the reader.
Message 8 of 9
(5,570 Views)
I like Bert's solution, but the latent Mathematician in me calls out for a Recursive solution (which, of course, is very simple to write in LabVIEW).  I made the input a U32, thereby getting rid of a possible ambiguity if you put in a negative integer.  I also assumed that the number 4409 (using our usual "digit-place representation" of numbers, has the digits "4", "4", "0", and "9".  Here is the (almost trivial) VI, showing the Recursive call -- this version puts the digits of 4409 in an Array starting with the Least Significant Digit (i.e. "9") -- reversing the order of building the Array will give the digits in the reverse order.  Enjoy!
U32 to DigitsU32 to Digits
 Bob Schor
Message 9 of 9
(5,545 Views)
