seperating signals
i have a big problem with labview 7.1
I have a Data-Tanslation DT 300 A/D-Card, and i want to measure with 3
seperate channels. I have a VI where almost everything works, but i
can´t find, where i can seperate the channels. The only icon i found
does not have an output, so i can´t store and draw the channels seperatly.
I hope you know what i mean, and i hope i get answers because i am very
desperate at this moment.
Bye Aeron
(2,556 Views)
You need to provide a little more information on the functions from DT that you're using. Their acquisition VI must be returning a signal in some format. If it's a 2D array, then you can use the Index Array function to get either the row or column that represents a specific channel. Attaching the actual DT VIs that your're using would help. Also, since it's DT code that you need to use, have you tried asking them about your problem?
(2,556 Views)
