serach array fron file
 Hi all
I need help please
I have ini file ( see attach) which include data inside
also I have string array which include these data
EEPROM
Calibration
Verify SN
BAT Value
HW Ver
I want to load min and max result from ini file , regarding to array input
what I mean
I you see that the ini file include line called [EEPROM] if the array have this infomarion I want load min and max result for EEPROM
and the next index in array is calibration I want to look into ini file and serach for this word is exsist I want to load min and max for this index
can any one help how to do that in labview 2013
thanks very much
(2,642 Views)
You should be able to find your question answered here 🙂
http://forums.ni.com/t5/LabVIEW/Read-array-from-ini-file/m-p/1406006
Derick Mathew
(2,633 Views)
edit
same link as above
(2,616 Views)
