serial communication errors
I am currently trying to use the Basic Serial Write and Read vi to communicate through my bluetooth adapter.  However, I keep getting the following error:
Error -1073807202 occurred at Property Node in VISA Configure Serial Port (Instr).vi->Basic Serial Write and Read.vi
This error code is undefined. No one has provided a description for this code, or you might have wired a number that is not an error code to the error code input.
I have allready tested my port with Hyperterminal and it works fine.  Can anyone help?
Sincerely,
Ray
(4,390 Views)
-1073807202 VISA: (Hex 0xBFFF009E) A code library required by VISA could not be located or loaded.
Is the VISA driver properly installed?
(4,381 Views)
Actually, I found my problem.  I haden't installed the measurements and autonomation so I suppose my VISA drivers weren't  installed correctly.  I am currently using the student versiona of labview 7 express which does not come with MAX.
Thank you for your help.
(4,375 Views)
SWO Nuke wrote:
<cut>
device drivers are not properly installed
(4,366 Views)
I do have another question.  I am trying to communicate to a basic stamp with my bluetooth adapter(on laptop) using serial port communication.  The basic stamp has a bluetooth adapter also connected to it.  However, I don't know what format the serial port sends data.  Is it Hexidecimal, ASCII, String, Decimal?
Sincerely,
SWO Nuke
(4,357 Views)
The simple answer is that everything that travels out of the UART is an ASCII character. The VISA Write function does not do any sort of conversion between what you feed in as a string and what goes out over the serial line.
You may want to take a look at this Serial Quick Reference Guide from NI. If you wire a string constant "ABC" to the input of the function then the data equivalent of "ABC" goes out. If you tell the afore-mentioned string constant to display its contents as hexadecimal ( which would equate to 41 42 43 ) then ABC still goes out exactly as before (it doesn't make any difference how the input constant is displayed). Everything has to be converted to an ASCII string before it is fed to the VISA Write function.
Don't make this too complicated by over-thinking it. It really is quite simple and straight-forward.
(4,351 Views)
