serial communication, unreadable output
I'm trying to read the data through serial port from a microcontroller based device. I'm using basic_serial_write_and_read.vi from the example section. the output I'm getting is unreadable (see pic).
Any ideas on what might be wrong?
Message 1 of 14
(8,920 Views)
Most likely the baud rate is incorrect.
Chris
Certified LabVIEW Architect
Certified TestStand Architect
Message 2 of 14
(8,918 Views)
Switch to hex display. Do you know for a fact that you are supposed to be reading ASCII?
Message 3 of 14
(8,912 Views)
I'm using usb to serial adaptor and my baud rate comes right from the device manager settings....
Message 4 of 14
(8,911 Views)
How do I switch to HEX display?
I know for a fact that its ASCII, this is how I programmed the microcontroller and I double checked it already
Message 5 of 14
(8,910 Views)
Its a right click option.
Message 6 of 14
(8,900 Views)
ok, I did it and that's what showed up (see att)
Message 7 of 14
(8,897 Views)
So, compare to what you read with a terminal emulator program. If its the same, you have a problem with the sender.
Message 8 of 14
(8,882 Views)
You also said something very strange about matching the settings in device manager. Those settings are totally irrelevant.
Message 9 of 14
(8,877 Views)
I'm using USB to serial adaptor, so when I right click on it and open properties it shows the port settings... aren't those settings supposed to match labview settings? or I'm missing something?
Message 10 of 14
(8,869 Views)
