serial communication using modbus protocol
Hello Friends!!
i want to make a communication of instruments based on modbus protocol with pc. we are doing it with opc server but its very complecated to make lpd & scf file.....so please suggest me a simple way of doing this.
(3,391 Views)
Have you tried using RS 232/RS 485 or TCP/IPalong with Modbus for serial comm?
- Partha ( CLD until Oct 2027 🙂 )
(3,377 Views)
ya right now we are doing it using RS 232 to RS 485 communication. for that we are using industrial automation opc server. even we have done it with visa but now we dont want to use these two ways....we want some other simple way for same RS 232 to RS 485 communication.
(3,372 Views)
Hi mom,
I think what parthabe was suggesting was to use the free LabVIEW Library found below.
Modbus LabVIEW Library
This library doesn't use OPC at all. It does however use NI VISA to connect to the instruments through either serial or TCP/IP. It is a very simple library and may be a great solution for a simple setup.
Asa Kirby
CompactRIO Product Marketing Manager
________________
Sail Fast!
(3,347 Views)
