serial communication
i have developed a project of DATA ACQ SYS where i m using two channels of ADC. To one channel, strathoscope(PCG) is connected and to other ECG sensor is connected. Now it will serially send the data from the same serial port but at labview it is showing 1 single waveform but i want different PCG and ECG waveforms.
(2,731 Views)
Hi neenu,
              It is difficult if you won't post your VI.
Thanks as kudos only:)
(2,728 Views)
