serial data in hex
rohitmalve wrote:
may be i am going on different track.But I am ryt now working with docklight only.I am facing an issue as follows:
This is a seven year old thread and your problem seems to be quite different. Are you sending a hexadecimally formatted string (letters 0..F delimited by spaces) or is this a binary string where you set the string indicator to hex display to inspect the contents?
Are you sure all communication parameters are set correctly?
Message 11 of 14
(1,146 Views)
Thanx for your kind reply.
Yes all the parameters are set correctly in docklight as well as on my receiver device as well.
You can see the attached image of what settings i am doing in docklight.The same serial settings are there in my receiver device.
Still I am getting the extra "FF" in my received data.I am receiving following data on my receiver device:
02 0B 10 1A 00 38 FF FF FF FF FF FF FF B1 10 67 03
Please provide some solution.
Message 12 of 14
(1,109 Views)
sorry forgot to attach image in previous message.Please find the attachment here.
Message 13 of 14
(1,108 Views)
Where's your LabVIEW code?
Message 14 of 14
(1,097 Views)
