serial help
OK, I have to read numbers (32 bit) coming from my serial port (COM2).
And I have to build aa array with them.
Can someone give me something working?
Thank
(2,827 Views)
you must use functions from "Functions->Instrument I/O->Serial" palette.
The idea is to do the next steps:
1.Open serial VISA session with specified COM port parameters.
2.Read specified number of data bytes from COM port.
3.Convert data from string format to array of I32 words with the help of "Functions->Advanced->Data Manipulations->Type Cast.vi"
4.Close VISA session.
The example is attached.
Also you may take a look at built-in LV examples.
Select from LV menu the next item:
"Help->Examples...->I/O Interfaces->Serial Communication->........."
Good luck.
Oleg Chutko.
(2,827 Views)
