serial key is not working
I used labview 2018 sp1 for quite a while,  I have an activation license and it's working, last month I install other version of labview , I don't know if it has something to do with my situation now, but my vision assistant keep saying that I need to activate it, when I put in the serial key, it says invalid serial number but it works months before. Anyone know how to solve this? attached pic below :
after trying to uninstall and reinstall, this happen
invalid for labview 2018 sp1
(1,659 Views)
If you have installed other versions of LabVIEW,  it is trying to activate the other LabVIEW you installed with the 2018 key.
(1,657 Views)
I think the primary reason is that it could not reach the activation server. Is the computer connected to the internet? Are there a very restrictive firewall policies? Anything else changed?
(1,649 Views)
it is connected to internet
is changing region the problem?
edit : nvm it isn't
(1,642 Views)
