serial number
I have just downloaded the trial version of the Visual aquisition software, and during the installation I have to insert a serial number, but I do not have it. How can i solve this problem?
(3,236 Views)
Hmmm... I just saw that page : http://digital.ni.com/demo.nsf/websearch/5b1e3d2913f0e670862574d40055a578?opendocument
but it doesn't give much information about how to obtain an evaluation licence number... and it then directs you to that page : http://joule.ni.com/nidu/cds/view/p/id/2552/lang/en
that only says this : "When you run an NI Vision application for the first time, it prompts you to activate a license for the product. If you do not activate a valid license, the NI Vision application will run in Evaluation Mode and continue to prompt you to activate a license on each subsequent launch."
but doesn't really help.
I suggest you contact your local NI Sales rep to request an evaluation licence number.
Hope this helps
We have two ears and one mouth so that we can listen twice as much as we speak.
Epictetus
Antoine Chalons
(3,227 Views)
I think the explanation Titou gave is meaningful and helps a lot.
The explanation states that if you don't have a valid licensed serial number, you will automatically use your Vision application in an evaluation mode.
You have nothing else to do.
Olivier L. | Certified LabVIEW Developer
(3,212 Views)
