hi,
i use VISA within LabVIEW 6.0 communicate with microprocessor(PIC18F452)
through serial port, ijust want to transfer some data to the MCU which is in
the PICDEM2 PLUS DEMO board.But i can not get correct data.Actually no
matter what i write to buffer, i always get same value. i use oscilloscope
to observe the waveform.Transmitting a byte takes about 8.2 ms while the
baud rate is set as 9600bps without parity,the duration is not correct.
any help will be appreciated
thanks lot
