serial port read.vi
there is this one other part.
 question...is there a way not to reinitialize the pressure data if the pressure_query is not in use.
Message Edited by krispiekream on 10-01-2008 10:25 AM
Krispiekream
Message 41 of 46
(1,476 Views)
my program changes the pressure when reading and trying to set the pressure. so maybe this code help.
Krispiekream
Message 42 of 46
(1,469 Views)
it look like i got it.
i hope i didnt break anything. but removing this subvi worked.
Message Edited by krispiekream on 10-01-2008 11:23 AM
Krispiekream
Message 43 of 46
(1,462 Views)
guess not. removing it also set pressure indicator to zero after a while.
but i am sure its the serial within pressure_sampletime.vi
Krispiekream
Message 44 of 46
(1,450 Views)
yup, after restarting my computer, it was pressure_sampletime.vi that was causing the problem.
the subvi call out for pressure_query.vi it and it doesnt do anything. so i removed it and  it work perfectly.
THANK YOU RAVENS FAN for helpping me with this issue. it has been fun.
Krispiekream
Message 45 of 46
(1,435 Views)
You're welcome.  I hope you'll continue to have good luck with your application.  Keep reading the forums.  I know I've learned a lot over the years doing that.
Message 46 of 46
(1,429 Views)
