serial port
I am building application,the application refers to
the Serial Port,But after the application building,the
serial port can not select? Which can not use.
I want to know why and what should I do?
Thanks in advance.
ying
Message 1 of 13
(5,090 Views)
If you are using VISA to sommunicate over the serial port, you need to make sure than VISA is included in the installation of the executable file. In most LabVIEW versions, there is an option to automatically include VISA in the installation generated by the application builder.
If you use aliases for the Serial ports, make sure to set up VISA appropriately on the new computer or else the software won't work either.
If you'te not using VISA, the serpdrv file needs to be in the same folder as the EXE to make the serial communication work.
Hope this helps
Shane.
Using LV 6.1 and 8.2.1 on W2k (SP4) and WXP (SP2)
Message 2 of 13
(5,083 Views)
Thanks Shane.
I understand what you said.But I have a problem.
In my application , I used the VISA , But What you said
"there is an option to automatically
include VISA in the installation generated by the application builder."
I can not find it .
Which part include the option of VISA in the Application builder?
I use Labview 6.1.
ying.
Message 3 of 13
(5,055 Views)
The build option Shane mentioned came as part of LV 7.X.
In your case installing VISA explicitly will get teh driver installed.
Then you have to check you VISAconfig.ini to enusre your ports are listed. Edit as required.
There is also a line in the LabVIEW.ini file
serialDevices="COM1;COM2;COM3;COM4;COM5;COM6;COM7;COM8;COM9;LPT1;LPT2;LPT3;LPT4;
that may do the same thing. Copy your LabVIEW.ini as your exe name and include it in the folder where the exe is run from.
Ben
Message 4 of 13
(5,052 Views)
Hello Ben.
In my computer, I can not find the VISAconfig.ini ,why?
I found the LabVIEW.ini file, but there isn't
which you said.
I want to know the function of the LabVIEW.ini?
Thanks again.
ying.
Message 5 of 13
(5,041 Views)
Search your hard drive for the Visaconfig.ini.
I do not think it was under the NI folder.
If you carefully examine the LabVIEW.ini file you will see that all of the preferences available in LV are stred therin.
These preference are also available in the built if the built find a ".ini" file in the same folder from which it was opened.
Ben
Message 6 of 13
(5,022 Views)
Bedause it is called visaconf.ini and resides by default under
C:/VXIPnP/<platform>/NIVisa/. Use WinNT or Win95 for <platform>
depending if you are using an NT system (NT4, W2000, WXP) or an older
one (Win9x, Me).
> which you said.
This entry does nothing for VISA. IT was used for the old sepdrv driver
in LabVIEW 5 and earlier.
Rolf Kalbermatter
Rolf Kalbermatter  My Blog
Message 7 of 13
(4,993 Views)
Hi Ying:
Can you still select your VISA Resource name on the development computer when you run your application? If this is only happening on a different computer you will have to either have VISA or the VISA runtime engine installed which you can get here:
http://digital.ni.com/softlib.nsf/954feaeea92d90918625674b00658b83/29a81c222112038f8625695700795810?OpenDocument
Also, check to be sure you can communicate in Measurement & Automation Explorer by opening a VISA session for the COM port in question. This is also where you can check what your VISA resource name is.
Emilie S.
Message 8 of 13
(4,786 Views)
Rolf wrote
"Because it is called visaconf.ini..."
Thank you for correcting!
Ben
Message 9 of 13
(4,967 Views)
Thanks for everyone.
Hello Emilie S.
Now, I build application about the Serial Port,
In the program i use VISA ,I found If i install
the VISA runtime engine , the application of the
serial port can use ,but if not install , the application
cann't use.So ,can I build Application contain the
VISA runtime engine?
Thanks.
ying.
Message 10 of 13
(4,717 Views)
