11-01-2007 12:46 PM
11-01-2007 01:28 PM
11-05-2007 07:26 AM
Hi CC,
I've already done that (varying the baud rate) and it it didn't work.
Celia
11-05-2007 09:34 PM
Few years ago, I had a problem with a poorly coded driver (not my work ;)) on a serial instrument. When hyperterminal was used to send data, everything was fine, but when LabVIEW was used, there were always transmissions errors. Of course everybody thought LabVIEW was the cause of the trouble. It wasn't. An undocumented delay of 0.1 sec was required between the transmission of each character, independently of the baud rate ! Of course typing in the commands with hyperterminal was fine...
In your case, everything works fine when you use a cable. And if you change the cable, you sometimes get errors. The wireless transmission introduces some kind of uncertainity in the connection. You could pick up random noise from a nearby source, possibly from your experimental setup. The fact that the transmission is working when using MatLab does not mean the problem is with LV. The problem is still will the transmission, but the way Matlab handles it is less prone to error with your wireles transmitter.
What I would do is to write a short test program to send frames of the same character and check the reception to see if the problem is random or appears for some given chars. Try also to insert a short delay between chars and see what happens.
Could you tell us the model of your wireless transmitter ? And the baud rate ?
11-06-2007 12:11 PM
Hi CC,
I finally found a problem with my remote transmiter hardware. There is a capacitor with a problem.
Thank you very much for your help.
Celia
11-06-2007 02:12 PM
Good to ear that ! 🙂
