serial string concat
I have a for loop and am trying to build a large string as an output.  The loop runs 10 times and I need to add each string output together to build one large string.  I tried the concatenate string function but it requires concatenates parrellel inputs.  Any ideas, thanks.
(4,860 Views)
You can use 'String concatenation' to concat an array of strings, just reduce the number of inputs to one (1).
Ton
My LabVIEW Ideas
(4,859 Views)
thanks for the reply, I am really just trying to append to the string with each itteration of the loop.  I tried to reduce the input to 1 for the concatenate string function but did not see how.
(4,856 Views)
This is a fairly basic question. Have you done any of the LabVIEW tutorials? Shown here are the two methods (and there's a third by using a Feedback Node instead of the shift register).
To learn more about LabVIEW it is recommended that you go through the introduction material, tutorial(s), and other material in the NI Developer Zone's Learning Center which provides links to other materials and other tutorials. You can also take the online courses for free.
(4,850 Views)
Some thing like this
Omar
(4,849 Views)
Thanks for the response.  Yep new to Lab View, but a long time C, C++ C# programmer.  Will look at the tutorials as well.
(4,823 Views)
