seriell connection under WINNT
I tried to send with the normal seriell VI some characters over com 2 and receive them at the same port. Therefor I make a connector for the PC wich connects PIN 2 and 3. But if I send something, I never get it by reading. Is this a problem of LabVIEW and Windows NT 4.0, because I tried this a year ago under win 98 and it worked.
TED
(2,650 Views)
For 9pin serial port you have to connect pins in such a way
2-3
4-6
7-8
For 25pin serial port
2-3
4-5
6-20
Good luck.
Oleg Chutko.
(2,650 Views)
For debugging purposes I would suggest using HyperTerminal with your null modem cable. This eliminates labVIEW from the equation and helps in determining if there is something wrong with the serial port.
If you go to www.ni.com you can do a search for:
+hyperterminal
you will find several webpages that tell how to use this Windows utility.
Chris_Mitchell
Product Development Engineer
Certified LabVIEW Architect
(2,650 Views)
