series of experiments in one run
hi all..
i am trying to do a series of measurements using magnetic field on a sample at low temperature. i ve labVIEW programs which work fine and takes data for a single run. but i want to modify it into a more general one- say, sweep magnetic field, take readings, wait for some 10 minutes, change temperature and then sweep back field to zero, again wait for say 15 min, and then change say gate voltage, and sweep up and so on.. theese changes are completely arbitaray and i want the user to plug in according to the requirements before each experiment, which basically consists of a series of runs plugged into one. so basically, i think it should be very general. so how can i put in all these variables and the whole series in the front panel? do i need to use some other programming language like C?
(2,412 Views)
It should be possible to realise such an application program using LabVIEW
You may have to think of a suitable architecture like a State Machine to do such an operation
(2,407 Views)
