serious Bugs in LabVIEW 2011
Dear Sir or Madam,
I have been working with LabVIEW for 10 years.
recently I have istalled the last version (LabVIEW 2011) and encountered some fundamental Bugs as bellow:
1-when I want to close LabVIEW 2011 Platform,it taks about 3 sec time to be closed ! while this was not in earlier version such as LabVIEW 9 sp1.
2-In a typical Front Panel,when I press Ctrl+M to chenge to Run mode,it went but after pressing Ctrl+M again,it will not exit from run mode(THIS BUG HAPPEN SOME TIMES NOT ALWAYS) or when I do right-click to view Function pallet or Control pallet,nothing happen!(THIS BUG HAPPEN SOME TIMES NOT ALWAYS).
I will be happy if you tell me what is the reasons and can I trust on LabVIEW 2011 for big projects or It is better for me to used LabVIEW 2009 as the past.
thank you for your kind attention.
Ata Rahai,
Specialist Engineer.
(3,302 Views)
1 - Wouldn't an upgrade to a newer version of software on the same machine carry the risk of decreased performance?
2 - In this situation, does clicking on Operate and clicking on Change to Edit Mode not work?
(3,267 Views)
In fact I install LV2011 in a new and fresh Windows OS.
No it does not work via Operate Menu.
(3,248 Views)
Not an issue with LabVIEW- Multiple versions can be installed on the same machine and operate in different name spaces.  BUT when you install device driver support or tool kits for a laundry list of LabVIEW versions bring a lunch.
(3,243 Views)
Not really what I meant. I was thinking that a version a couple of years newer might be a little more taxing on system resources.
(3,238 Views)
Hi
I believe that 2011 is a very stable version (I was beta testing) and in my system the CtrlM works both ways, always.
Taking a few seconds to close is normal since version 8.0, depending on how many services are running. LV does clean up the system.
greetings from the Netherlands
(3,189 Views)
Thank you Albert.
I think XP OS is the best for LabVIEW platform since COM Port works better and LV is faster compare with W7 OS.
(3,166 Views)
