server failur
Thanks for your guides; I'm considering them to find a solution. But the problem you mentioned," Error -1967362038" already exists. When I want to configure and test the database in ODBC Data Sources Administrator, test connection is successful but when I hit OK, the program doesn't respond. Maybe there is relationship between them. I appreciate you for your guides.
Message 11 of 12
(899 Views)
Hi Maryam,
You mentioned in that post that the problem only arose when you moved computers.  Also I found a number of documents that refer to this error arising when you loose the connection with bound variables.
Resolving the problems outlined on this forum , ie making sure all your variables have been bound to the correct source and are deployed should resolve the issue with your database.
If not post back on this forum:
http://forums.ni.com/ni/board/message?board.id=170&message.id=188425
with the status of your application.
Sarah
Applications Engineer | National Instruments | UK & Ireland
Message 12 of 12
(893 Views)
