05-02-2012 03:50 PM
So there is absolutely no way I cant do it other than using a DAQ card right.
And I do have a NI DAQ CARD but sad thing is my motherboard doesnt have PCI slots. Its all PCI E slots
There is no alternative way at all I can go around this right.
05-02-2012 04:22 PM
Gotcha !
I have now PCI-MIO-16E-1 DAQ card from NI using PCI slot
SCB 68 pin connector
Will these help me in getting the servo to run ?
Do I have to install any DAQ CARD drivers on my system for this ...
05-03-2012 09:06 AM
There are other options to control your scanners but they don't make much sense for you. CTI makes several controllers that allow you to create a pattern in your PC and then send it down to the servo (which drives the galvos). Unfortunately these are more expensive than a basic DAQ card AND they won't read your sensor so you'll still need a DAQ for that.
Your PCI DAQ card will work since it has 2 outputs and 16 (multiplexed) inputs BUT it's only 12-bit so your image resolution is not going to be as good as a cheap 16-bit card. More importantly, it's really old , you'll have to use the old (traditional) DAQ drivers instead of the new DAQmx which is much better and easier. If you want to use it I suggest you try and install it first. It may not even work if you're using a newer OS as it's designed for Windows 98! If it does work prepare to spend a lot of time reading manuals and coding the DAQ VIs ...
05-03-2012 09:53 AM
Yeah I have Vista with LabView 11 installed. However under measurement and automation explorer , it shows the card ... does that mean the drivers are installed automatically ? or I still need to install traditional DAQ drivers for this ...
05-03-2012 12:19 PM - edited 05-03-2012 12:24 PM
Good news, I was wrong! There appears to be a version of DAQmx that will run your old card under Vista. It's here: http://joule.ni.com/nidu/cds/view/p/id/2337
Bad news, it's a 1.2 GigaByte download.
More bad news: according to this: http://digital.ni.com/public.nsf/allkb/B0D5630C0A50D5C6862578E800459248 It won't work in LV 2011 (or maybe it will ).
DAQmx 9.3.5 WILL work with 2011 and SHOULD work with your card but I can't find a link to download it. You may need to call NI and get a straight answer from their engineers before you waste time downloading and trying out things that may not work.
After you install everything you should be able to connect up the physical inputs and outputs and try to generate and read some signals. Check out the DAQmx examples in the Example Finder to get started with that part...
Then you'll need to code up the main application which will move the stage, scan a line, display and store, move the stage, etc. This is a job for the State Machine architecture. Search for info on this board if you need help with that. There's lots of threads about it because it's very useful and popular.
EDIT: Forgot to add, before you do anything look in MAX under software and see if you already have a version of DAQmx. You might as well try it out before you download a huge file.
EDIT2: You can also try out the functionality of the DAQ card right in MAX. Click the card name and go to the test panel tab.
02-09-2014 11:00 AM
Hi there,
good wishes.
I've been working on servo motor drive(MITSUBITSHI) control through PC parallel ports(25 pin db connector). I'm not wishing to do this with any kind external cards or additonal circuits. let me know, is there any software is already available in the market ,to control the drive via pc parallel ports. please help me in this concern
02-10-2014 09:47 AM
There isn't any software for that because it's not physically possible. A servo motor is a motor with a fast analog servo to provide feedback based control over the motor position. A PC Parallel port is digital and cannot control it no matter what software you have. If you mean stepper motor then yes, you can control it with the parallel port but you would be better off buying a new stepper interface..
02-20-2014 03:03 AM
tanx for your text. please help me again: please give me your email
