set NI6501 device as input
Hi all  I have NI 6501 device ( digital I/O),, I want to set its port as input ,, can any one help me with this
thanks
(2,384 Views)
With the DAQmx Create Channel, you just have to click on the polymorphic selector (the box below the function) and change it to Digital Input. Then create a physical channel control/constant and pick your lines or ports. The DAQ Assistant will do everything for you. You should also look at the shipping examples.
(2,379 Views)
