set a timeout for "read from text file"
I Need to read from a text file on a remote pc and use the read from text file function to do this. It wotks but sometimes this pc is down causing long wait times in my vi.
Is there a way to set a timeout for the read from text file function, or is there an other solution?
Thank you
(2,615 Views)
You could check that the path is valid first before you attempt to read the file.  hen put the file read in a True-False case structure based on the results of the check.  You can use the function "Check if File or Folder Exists"  It checks whether a file or folder exists on disk at a specified path. This VI works with standard files and folders as well as files in LLB files.   The function is found in the File I/O --> Advanced File Functions palette.
Tom
(2,595 Views)
Tom,
I use a ping first before attempting to read the file and can now avoid reading a file on an off pcSmiley Happy.
Thank you again
(2,583 Views)
