set and reset RTS Line of the Serial Port
Hi there,
I have a external Hardware which is not very stable, so it often hangs up, and the only way to reset it, is to set the RTS Pin of the serial Port to high and then to low.
With an Terminal Program this is no problem, but how can I do this with LabVIEW? I'm using the Serial Compatibility VI's to use the Com Port.
Does anyone have a, solution to steer the RTS PIN manually?
I'm using LabView 6i
Thanks a lot
Markus
(3,362 Views)
..\vi.lib\platform\_sersup.llb --> serial line ctrl.vi
(3,362 Views)
Thanks, I have found the solution in this example
Greetings Markus
(3,362 Views)
