set default analog output in MAX
I would like to set a default value (e.g. 10V) to my analog output of my NI6251 card. The current value is (I assume) 0 V.
Is there a way to change the default value without using labview?
Many thanks
(3,023 Views)
I'm pretty sure you can't set the default analog output of a DAQ card to something other than 0V even using LabVIEW.  When the device powers up it will reset and set all outputs to an inert state which is a good thing for safety conserns.
I'd recommend you redesign your system so it too uses this standard of using the inert state of a startup condition.  What kind of system do you have that you want the off state to be 10V?
(3,010 Views)
