set focus to a control
good evening
I have the attached VI which accepts 3 types of information fro user,
the problem is that to write into the first field (ie: Eng COde...)
i have to click on it with the mouse( it gets focus), manually and then to input the inforamtion
my question is , how to cause this field to be focus already when the VI is executing
in order to ovoid the need for mouse click..just be ready for the input data
thank in advance
Simon.I
Message 1 of 9
(9,298 Views)
You'll have to convert the Express VI to a normal VI. Right click and select Open Front Panel. With it converted, you can create a Key Focus property node for the control.
Message 2 of 9
(9,290 Views)
I will file a bug report to have the Express VI changed. In the meantime, you will have to do as Dennis suggests; i.e convert the Express VI and edit it. Insert a property node for the first control between the FP.Open and the while loop and set property KeyFocus to true.
Message 3 of 9
(9,281 Views)
Since i am new to LBV can you tell me how to do this?
simon.i
Message 4 of 9
(9,272 Views)
After you place the VI on the block diagram, right click on it and select "Show front panel". LV will ask you if you want to convert the VI. Click "convert". Go to the block diagram of the VI and right click the control you want. Select Create>>Property node. A property node for that control will appear. Click where it says property and select Key Focus. Right click it and select "Change to write" and place it where it needs to be. Give the VI a name and save it.
___________________
Try to take over the world!
Message 5 of 9
(9,263 Views)
thanks, i managed, it looks fine
Now, it runs ok when it runs from LBV7, but when i activate it from TS2 (normal operation)
it doesnt get focused.
please advice..
Simon.I
Message 6 of 9
(9,258 Views)
thanks again
i am attaching the VI's,
as i said before, from LBV7 it runs ok ,as desired..
but from TS2 the control not focused as needed
please advice
thanks in advance
Simon.I
Message 7 of 9
(9,255 Views)
Hi Simon,
I'm not sure why the VI would execute differently from TestStand than when run from LabVIEW. Did you resave the VI with a different name? Make sure that you're calling the VI with the right name from TestStand. If this still doesn't help, let us know.
Hope this helps!
Travis H.
Travis H.
LabVIEW R&D
Message 8 of 9
(9,232 Views)
You probably need to make the panel modal to TestStand window. I think there is an example in the examples folder of Teststand.
Also, you really should continue the error chain from sequence 2 on to sequence 3 and out.
regards
Ray Farmer
Regards
Ray Farmer
Message 9 of 9
(9,227 Views)
