set geometry invoke node : do not have this method (and why is it red?)
Hi All,
So I am taking my first steps with the 3D picture control, and I am stumbling on the very first hurdle!
How do I create a "set Geometry" invoke node, as shown in this picture? If I wire an invoke node into the output of the Create Object I get a standard invoke node with several options, but none related to Geometry.
Second question: why is the invoke node red????
(3,507 Views)
Accepted by topic author Neil.Pate
Finally found the reason:
set Geometry was deprecated in LV8.5, as from the help:
Deprecated Properties, Methods, and Events
LabVIEW 8.5 does not support the following properties, methods, and events:
The Using Meshes example in LV needs to be updated as it still uses this deprecated method.
The Solar System example correctly uses set Drawable.
(3,504 Views)
