set meter control digital display BG and FG color
the digital display of meter control have BG and FG color setting property?
(2,539 Views)
There is no property for setting FG and BG for Meter Control. you can Change the Color if you need.
Please do share us what exactly you need to achieve with the above requirement.
Palanivel Thiruvenkadam | பழனிவேல் திருவெங்கடம்
LabVIEW™ Champion |Certified LabVIEW™ Architect |Certified TestStand Developer
Kidlin's Law -If you can write the problem down clearly then the matter is half solved.
(2,459 Views)
Hi weschen,
the meter control also provides properties to set FG and BG colors:
(2,446 Views)
I means the meter digital display control(BG-blue,FG-white).
(2,422 Views)
Accepted by topic author weschen
If you scroll to near the bottom of the property node list, you should be able to find a category for the digital display properties.
You'll find the options you need for color there.
The links from this link Digital Display may be helpful (see the text properties link and the class information
Numeric Text Properties for the MeterNumeric Text Properties for the Meter
Note in the example above, the Meter's "Digital Displays[]" returns an array of references. I use Index Array to get the first (and only) reference and then manipulate that reference.
GCentral
(2,406 Views)
