set path to My Computer Directory
hi need help i have a file dialog
when ever the vi runs it must start path at My Computer how to do that?
(5,532 Views)
HI,
Your text doesn't explain your problem in a clear way. Try to explain it better, please!
Software developer
www.mcm-electronics.com
PORTUGAL
(5,514 Views)
Hi, Jorge,
I guess, I can explain the problem mentioned above. 😉
Jeyanthi tried to set default path for Open Dialog to "My Computer" and unable to do it (because "My Computer is not folder and not part of the file system).
I think its nearby impossible with embedded LabVIEW dialog, because default path should be set to ::{20D04FE0-3AEA-1069-A2D8-08002B30309D} in this case, and such path prohibited by LabVIEW. This may be possible with .net Open Dialog.
best regards,
Andrey.
Message Edited by Andrey Dmitriev on 06-25-2008 12:55 PM
(5,509 Views)
