set scale values when zoom out
Hi!
I have a XY Graph and I want it to have three different scale ranges depending on a case structure. So, for example, if it's case 1, I have the xy graph X.minimum = 1,234 and xy graph X.maximum = 10,789 and so on.
I want to be able to zoom the graph but then when I zoom out to see all the points, I want it to have the same range I defined. I have the autoscale turned off and when I do the zoom out, it shows me different minumum and maximum values....
Any help?
(3,066 Views)
I forgot another thing. I want to make sure that if I use the pan tool, I can only see bettwen the range I defined, also.
(3,064 Views)
Hello Zephirus,
When you ask a zoom out, write the scale value that you define, using a property node. To get it, right click on the XY graphe terminal, in the diagram, then select Create >> Property node >> X (or Y) Scale >> Range then All elements, or just the elements you need to coerce.
Let me know you progression,
Message Edité par Mathieu R. le 11-14-2006 02:52 PM
(3,040 Views)
Hi!
Thanks for your answer. Now t's working like I wanted. Smiley Happy
zephirus
(3,028 Views)
