set the benchmarking VI to "time critical priority",
how i can  set the benchmarking VI to "time critical priority",
(3,555 Views)
Go to "File...VI properties...Execution". You'll find it. 😉
Be aware that time-critical priority is usually not a very good idea, especially for lenghty calculation, because it can starve all other processes running on the computer. (For example, I would loose my wireless internet connection).
(3,551 Views)
thank you altenbach in another thread you write about control times smaller then 1 ms. I have a board 6023E and i need goode precision it is possible and how i can have tis precision
(3,545 Views)
You just setup a DAQ task and the desired timings will be handled by the board timers. You would not use single point acquisition in a software timed loop anyway. Your software loop does not need to be deterministic, just get the buffered data from the board at somewhat regular intervals.
If you need to run a software control loop deterministically at <1ms, you would need LabVIEW RT or most likely FPGA. This is not something for low-cost hardware running on a multipurpose OS.
What exactly are you trying to do?
(3,537 Views)
I want make time resolved photoluminescense and for this i have a pulsed laser with trigger and i need put a delay after laser pulsed and i only later  can begin to measure . This delay is smaller than 1ms
(3,533 Views)
