set the cursor busy steered by supanel vi
I let run a vi and there is a subpanel. Is there a way that I can set the cursor busy steered by the subpanel vi. I pass the reference of the mainvi over a global variable into subvi. Without success there is no error message but the busy cursor does not appear. Just setting the cursor in subvi creates a null window error. Is there a easy way to implement it. Or do I have to use user events in main vi called by suvi an then se it busy. Would be not so nice to understand it later.
kind regards reto
(4,163 Views)
I try to implement it, but do not encounter your problem.
In mainvi
1. Pass mainvi reference to a global.
2. Insert subvi reference to sub panel.
3. Run subvi by reference and do not wait until done.
In subvi
1. All in a infinite while loop.
2. Read mainvi reference from global.
3. Set cursor busy.
The only problem I encounter is that since the cursor is set busy in mainvi, it is unable to close the mainvi by click Abort Exec button. 🙂
I don't think it is a good idea to set cursor busy steered by the subpanel vi.
(4,152 Views)
Are you setting busy in the subvi?
(4,148 Views)
I attach my test VI (LV 8.0). You can try it.
(4,145 Views)
Thank's: It's working well.
(4,141 Views)
