set up for 9221
I just recieved my USB 9221 DAQ module. Setting up the software is not working? I have attached a jpg picture. Any ideas how ro get the 9221 to aquire data? I need one channel to read data at the dastest sample rate.
(2,664 Views)
That timeout value is in milliseconds.  I'm not sure how you have tha task configured but my guess is that you are not sampling at 6.7MHz so the 0.12 second acquisition is going to have fewer than the 800,000 samples you requested.
(2,660 Views)
If my test takes takes 22 seconds. I am ramping voltages and holding for 50 miliseconds to 5 seconds. The power amp has a response time of 10 microseconds. How would I set up the 9221 to read at least a 1 MS rise times?
(2,658 Views)
Hello pnielsen@gplains.com
Have you been successful in viewing a test or creating a task in Measurement and Automation Explorer?  May I recommend some of our buitl in examples in LabVIEW?
Can you please describe your project architecture in detail so that I can better assisst you with this issue?  Thank you very much!
Sincerely,
Greg S.
(2,624 Views)
