setting Strings[] property of empty ring array creates first element
Title says it all. To me, it looks as a bug (or am I missing the logic?). I am on LV8.5 linux, but remember having seen such things with earlier versions and on windows too.
I attach a very simple test snippet. "Array of rings" has initially size 0, I don't understand why after writing the property it grows to size 1.
Any ideas?
Thanks, Enrico
Message 1 of 10
(5,475 Views)
Hi Enrico,
i see no problem. First you set the size to zero, and then you set the value of one array element. I think it is ok i think it´s no bug. Smiley Happy Wherefore do you need it?
Mike
Message Edited by MikeS81 on 04-03-2008 12:57 PM
Message 2 of 10
(5,460 Views)
But I'm not setting a value! I am setting only the item description strings, and IMHO that should not create any array element. If the array was already populated, no new element would be created.
The obvious workaround is to restore the original array content after having set the property, like in the attached, but the fact that this is needed for an empty array and superfluous otherwise makes me think of a bug.
Enrico
Message 3 of 10
(5,453 Views)
Hi Enrico,
I have modified your code by swapping 3rd sequence with 1st sequence.
Another work around would be to create the text ring control>>right click>>edit items>>then add it to the array
I will look into this more.
Hope these work arounds help
Message Edited by Van_L on 04-04-2008 01:41 PM
Van L
NI Applications Engineer
Message 4 of 10
(5,413 Views)
This is a bug.  We should not allocate array elements for setting properties (other than value) on the element DDO.  I could not find a request for this bug, so I filed one: CAR #101612
Jeff Peters
LV R & D
Message 5 of 10
(5,396 Views)
aha, that was my point, not which workaround is shorter. Thanks for filing the bug entry for me, I'm not familiar with the LV tracker.
Enrico
Message 6 of 10
(5,367 Views)
Has this bug been fixed in LV8.6? I'm still using LV8.5, where the bug was found.
Message 7 of 10
(5,028 Views)
I just wanted to add that this bug does not occur when you update the Strings And Values[] property, just the Strings[] property. That was my workaround for now.
Message 8 of 10
(5,022 Views)
Sima,
A list of bug fixes for 8.6 is found in the LabVIEW 8.6 Bug Fixes document, searchable from the ni.com homepage.  Look in there for the CAR# previously filed and referenced in the above post and you will find your answer Smiley Happy
Rob K
Measurements Mechanical Engineer (C-Series, USB X-Series)
CompactRIO Developers Guide
CompactRIO Out of the Box Video
Message 9 of 10
(4,989 Views)
Doh! Thanks!
Message 10 of 10
(4,979 Views)
