setting a pulse time in LabVIEW (using an instrument)
Hey,
in my VI I want to generate RF pulses like a spin-echo signal (MRI). To set it up I need to adjust the Pulse Time. As you can see in my VI I'm using an signal generator with a standard waveform to generate a signal. How I can implement the pulse time? For a normal RF pulse I want to start with a Sinc pulse with a start time from 2,5 ms.
Thanks and best regards!
Message 1 of 1
(963 Views)
