setting cell size in table
I would like to use property nodes to programmatically setup a data table with an overall table size of H=674 W=311. Then, within this overall size, I would like to programmatically set it up to display 7 columns and 15 rows of evenly sized cells. Is this possible? I've been able to set the overall size but I can't figure out how to set cell sizes.
(3,508 Views)
This will set the table up just like you want. The only problem is with the scrollbars, you can either turn them off if this is as big as the table will get, or subtract about 25 before you divide by the number of rows to get the individual height and width.
(3,504 Views)
thanks much!!! I'll try that
(3,501 Views)
