setting the x and y scale on an intensity plot using an array of x and y data
Hi
I have seen some past posts on this subject but am still none the wiser.
I realise one can set the x and y scales manually using the scaling factor tool in graph properties.  However what I would like to do is set the scales programatially using an array of x values and array of y values.  Is there an easy route to this?
Many Thanks
Ash
(2,824 Views)
You can use property nodes just like any other graph.
Paul Falkenstein
Coleman Technologies Inc.
CLA, CPI, AIA-Vision
Labview 4.0- 2013, RT, Vision, FPGA
(2,818 Views)
Yes very simple.
I forget things you know.  I am over 30.
Ash
(2,812 Views)
No problem, I am lucky if I can remember what I was trying to remember.
Paul Falkenstein
(2,804 Views)
