setting up a .net event hanler for msgqueue
I wish to set up an event handler for a msgqueue like in the following c# code: any ideas?
private const string PROVIDERQUEUE= @"Archimedes\SMTLabelQueue";
/// The main entry point for the application.
[STAThread]
static void Main(string[] args)
// Create an instance of MessageQueue. Set its formatter.
MessageQueue myQueue = null;
try
myQueue = new MessageQueue(PROVIDERQUEUE);
catch(Exception)
myQueue.Formatter = new XmlMessageFormatter();
// Add an event handler for the ReceiveCompleted event.
myQueue.ReceiveCompleted +=
new ReceiveCompletedEventHandler(youhavemail);
// Begin the asynch
ronous receive operation.
myQueue.BeginReceive();
while(Console.Read() != 'q');
static void youhavemail(Object source,
ReceiveCompletedEventArgs asyncResult)
MessageQueue mq = null;
try
// Connect to the queue.
mq = (MessageQueue)source;
mq.Formatter = new XmlMessageFormatter(new Type[] {typeof(string)});
// End the asynchronous receive operation.
Message m = mq.EndReceive(asyncResult.AsyncResult);
Console.WriteLine( m.Body.ToString() );
catch(Exception e)
Console.WriteLine(e.Message);
// We want to continue reading messages even if we couldn't update the state.
finally
// Continue reading messages
mq.BeginReceive();
(2,856 Views)
Unfortunatelly LabVIEW does not support .NET events, if you must catch .NET messages you can probably create a dll that catshes those events for you and transfers them to LabVIEW somehow.
You may want to look at ActiveX to send data to LabVIEW, there is a quite complete interface that allows for events and data transfers.
Just my 2 Cents.
Juan Carlos
(2,856 Views)
